Gönderen Konu: MiscEl  (Okunma sayısı 4059 defa)
MiscEl
« : 25 Kasım 2010, 20:53:04 »
Miscellaneous = Çeşitli
Elektronik Hesaplamalar Programı
Linkback: https://www.radyoamatorleri.com/index.php?topic=649.0
« Son Düzenleme: 25 Kasım 2010, 21:03:38 Gönderen: TA2CMC »
Ynt: MiscEl
« Yanıtla #1 : 27 Kasım 2010, 20:55:50 »
Değişik Hesaplamalar (Online)
CSG's Online Calculator - General Math
8051 Microcontroller Peripheral Timing Calculator
Acoustic Reverb Delay (RT60) Calculator
Active Audio Filter Calculator
Amateur Radio TVI Troubleshooter
Anode Resistor Nixie Tube Calculator
Astable 555 Square Wave Calculator
Atmospheric Sound Absorption Calculator
Audio Pre-Amplifier Calculator
Battery Charge Time Calculator
Battery Charge Time Variable Efficiency Calculator
Board Etch Run Impedance Calculator
Capacitor Information, Converters and Calculators
CCD Focal Length Calculator
CCD Object Resolution Calculator
CCD Object Size Calculator
Coil Frequency From Wire Length Calculator
Dielectric Constants Of Various Materials Table
DIVX Bitrate Calculator
Electrical Harmonics Calculator
Electronics Hobby Project Information
Frequency Wavelength Calculator
General Device Frequency Information
Gold Foil Sheet And Gold Wire Weight Calculator
Helical Primary Turns Calculator For Coils
Impedance And Resonant Capacitor Calculator For Coils
Inductance Calculator For Spiral Flat Coils
Jar Capacitance Calculator For Coils
LED (Multiple) Circuit Power And Series Resistor Calculator
LED (Single) Circuit Power And Series Resistor Calculator
Metric Capable Calculators, Converters and Tables
Monostable 555 Timeout Calculator
Ohm's Law Calculations
Ohm's Law Calculations With Power
Op-Amplifier Calculator
Parallel Resistance Calculator
Percentage Calculator
Peukert Number Battery Life Calculator
Resistance Array 5% Tolerance Calculator
Resistance, Capacitance, Voltage, And Time Calculator
Resistor Color Code Table And Calculator
Standard Resistor Values Less Than 100 Ohms
Standard Resistor Values Less Than 100 Ohms Calculator
Speaker 70 Volt Powered Line Calculator
T-Pad / H-Pad Resistance Calculator
Telephone Alpha Representation To Number Conversion
Telephone Number To Alpha Representation Conversion
Transformer Values Calculator
Series Resistance Calculator
Speaker Combination Decibel Calculator
Speaker Decibel Change Calculator
Speaker Decibel Change From Voltage Change Calculator
Speaker Decibel Power Change Calculator
Speaker Sound Q Calculator
Speed Of Sound Converter
Transistor Simulator And Calculator
Video Camera Disk Storage Space Calculator
Visual Resistance Calculator
Voltage Divider Calculator
Voltage Drop Calculator
Wire Length From Coil Frequency Calculator
Zener Diode Calculator
