Gönderen Konu: JAPONYA ULUSLARARASI DX YARIŞMASI 2015  (Okunma sayısı 2494 defa)
« : 09 Kasım 2015, 00:24:55 »
** RULE CHANGE! ** 1. Deadline is shortened. 1month after the contest.
OBJECTIVE: For amateurs around the world(DX) to contact JA stations in
as many JA prefectures + JD1 islands as possible.
For amateurs in Japan to contact DX stations in as many DXCC entities
and CQ Zones as possible.
1. CONTEST PERIOD
  CW Start Sat. 0700 -Sun. 1300UTC 2nd full weekend of April
  PH Start Sat. 0700 -Sun. 1300UTC 2nd full weekend of November
  PH 2015-11-14 0700 - 2015-11-15 1300 UTC
  CW 2016-04-09 0700 - 2016-04-10 1300 UTC
2. BANDS:
  PH     3.5/7/14/21/28MHz
     (JAs on 3525-3575, 3599-3612, 3680-3687, 3702-3716 3745-3770 & 3791-3805KHz
             7030-7200KHz also)
  CW 1.8/3.5/7/14/21/28MHz (JAs on 1810-1825 & 1907.5-1912.5KHz)
  Exclude the WARC bands.
3. ENTRY CLASSIFICATIONS:
      **** CHOOSE ONLY ONE! ****
   3-1.Single Operator(*1) High Power(*2)
    Abbreviation = category
      AB = SINGLE-OP ALL-BAND HIGH-POWER
      28 = SINGLE-OP  28MHz SINGLE-BAND HIGH-POWER
      21 = SINGLE-OP  21MHz SINGLE-BAND HIGH-POWER
      14 = SINGLE-OP  14MHz SINGLE-BAND HIGH-POWER
       7 = SINGLE-OP   7MHz SINGLE-BAND HIGH-POWER
     3.5 = SINGLE-OP 3.5MHz SINGLE-BAND HIGH-POWER
     1.8 = SINGLE-OP 1.8MHz SINGLE-BAND HIGH-POWER
   3-2.Single Operator Low Power(*3)
     ABL = SINGLE-OP ALL-BAND LOW-POWER
     28L = SINGLE-OP  28MHz SINGLE-BAND LOW-POWER
     21L = SINGLE-OP  21MHz SINGLE-BAND LOW-POWER
     14L = SINGLE-OP  14MHz SINGLE-BAND LOW-POWER
      7L = SINGLE-OP   7MHz SINGLE-BAND LOW-POWER
    3.5L = SINGLE-OP 3.5MHz SINGLE-BAND LOW-POWER
    1.8L = SINGLE-OP 1.8MHz SINGLE-BAND LOW-POWER
   3-3.Multi  Operator (*4)
     MOP = MULTI-OP (SINGLE-TX ALL-BAND HIGH-POWER)
   3-4.Maritime Mobile(*5)
    MM = MARITIME-MOBILE
# All categories, except Multi Op, only one transmitted signal is
  allowed at any one time.
# All stations can use the spotting network(like DXsummit).
# No SELF-SPOTTING of any form is allowed in all categories.
  Self-spotting is defined as generating spots for your contest
  callsign by yourself.
# All stations, except Maritime Mobile, must not change the operating
  location in entire contest period.
# Anyone may only submit one entry in spite of the callsign used.
  Submission of check logs for operation on other bands or other
  callsigns are encouraged.
# JA stations must sign their call area as "/#" if they operate from
  different call area against their callsign.
*1  Single operator must do all contest related things by himself.
   +Single-Operator can change bands at any time.
   +Multiple Single-Operator entries from the same location must use
    different callsigns.
*2  High Power: Output power 100w over
*3  Low  Power: Output power 100w or less
*4  Multi Op station must remain the same band at least 10 minutes
    when they make the contact on that band (RUNNING station).
    They can transmit one other band simultaneously only when the
    station worked is a new multiplier (MULTIPLIER station).
    The above 10 minutes rule will be applied to each RUNNING station
    and MULTIPLIER station separately.
*5  All Maritime Mobile stations must sign "/MM" after the callsign.
    They will send CQ-Zone number for exchange with JA stations only.
    Their scores will be listed in the result but not eligible for the
    awards.
4. CONTEST EXCHANGE:
   JAs   : RS(T) + Prefecture number(01 to 50)
   Others: RS(T) + CQ Zone number
   You can download the Prefecture number= jidxmult.lst
5. POINTS:
   Only contacts between JA and DX(+/MM) are worth contest points.
(DX-DX, DX-/MM or JA-JA contacts are no point and no multi)
      1.8MHz................. 4pts
      3.5/3.8MHz ............ 2 points
      7MHz, 14MHz and 21MHz.. 1 point
      28MHz.................. 2 Points
The same station may be worked only once per band.
No cross mode, cross band nor repeater contacts are allowed.
6. MULTIPLIER:
JAs   :The number of different DXCC country (except JD1) and CQ
       Zone worked on each band.
       QSO with /MM stations is worth for Point and Zone multi but
       no Country multi.
Others:The number of different Japanese Prefecture plus Ogasawara
       Is.(JD1), Minami-Torishima Is.(JD1) and Okino-Torishima Is.
       worked on each band. Maximum of 50 (See the List) per band.
7. SCORING:
   The final score is the result of the
(Total QSO points) multiplied by (Total multiplier).
Ex. 100 QSO points x 59 multi = 5,900
8. LOG INSTRUCTIONS:
** Only one log is accepted for the result regardless of the callsign used.
8-1. All times must be in UTC.
8-2. All sent and received exchanges are to be logged.
   **DO NOT FORGET TO RECORD YOUR ZONE/PREFECTURE ON EITHER LOG or SUMMARY**
8-3. Indicate the new multiplier only the FIRST TIME it is worked
   on each band.
8-4. Duplicate contacts on same band must be clearly shown and
   marked as 0 QSO point.
8-5. Electronic Log:
   Please follow the ELECTRONIC LOG instructions. You can send it by
   following 2ways to the committee.
   DISK LOG: MS-DOS compatible 3.5" disk only. (No 5" disk or Mac format)
   EMAIL LOG: send the Log file as email attatchement.
   The instruction  [jidxelog-e.html] is here.
   send your email logs to
      cw@jidx.org
      ph@jidx.org
8-6. Use a separate sheet for each band.
   Use a separate sheet for Multi Op, RUNNING and MULTI station.
8-7. Each entry must be accompanied by a summary sheet showing all scoring
   information, class of entries, name and address in BLOCK LETTERS, and a
   signed declaration that "All contest rules and regulations for amateur
   radio in the entity of operation have been observed. JIDX Contest committee
   decision is final"
8-8. All entrants, except Electronic Log submittion, are required to submit
   dupe-check sheets (an alphabetical list of calls worked) for each band if
   200 or more QSOs were made on that band, or for all bands if a total of 500
   or more QSOs were made.
9. PLAQUES:
Plaques will be awarded to the winners which have donnors.
The Single Op/Sigle band plaques will be awarded to the highest
scorer regardless of the High/Low power category.
10.AWARDS:
   First(plus 2nd & 3rd, depending on number of entries) place
certificates will be awarded in each class in every entity and
in each call area of the USA if the station got SUFFICIENT* score.
 *What is sufficient? Depending on the band conditions, activities
  etc, judged by the committee.
 *Plaque winners will not receive the printed award.
11.REPORTING:
   A original log and a summary sheet will be requested with a SAE
with one IRC but any log forms will be accepted.
All logs should be sent to
   JIDX "PHONE/CW" Contest
   c/o FIVE-NINE MAGAZINE
   P.O.Box 59, Kamata, Tokyo, 144-8691 Japan
The contest results will be sent with one IRC and SAE.
Email log submissions will be judged with the time stamp of the email
and it should be sent to;
Separate addresses for each (Phone & CW) contests NOW!!
Please use the following email addresses;
CW   : cw@jidx.org
Phone: ph@jidx.org
   (Log submissions only)
The acknowledgment will be sent when the email log is received and
the result also will be sent by email.
Email Log Submission Guide is available here.
CABRILLO FORMAT is recommeneded.
13.Deadline:
   No later than ONE month after the end of contest.
   PH 2015-12-15
   CW 2016-05-10
   The deadline will be extended up to 2 weeks if the JIDX contest committee
accept the request with the reason by email prior to the deadline.
   Email: jidx-chairman@jidx.org
12.DISQUALIFICATION:
   Violation of the contest rules.
   False statement in the report.
   The decision of the JIDX contest committee is final.
13.Information on the Internet
  You'll be able to get JIDX related informations at the
JIDX Official HomePage.
   JIDX contest committee chairman
   Tack Kumagai JE1CKA/KH0AM
   Internet: jidx-chairman@jidx.org
JAPONYA ULUSLARARASI DX YARIŞMASI KURALLARI
* KURAL DEĞİŞİKLİĞİ! **
Sertifikalar   indirip print edebileceğiniz  PDF formatında olacaktır. Nasıl ve nereden indirilebileceği bilgisi daha sonra duyurulacaktır.
AMAÇ:
Japonya dışındaki tüm DXCC amatörlerinin mümkün olduğunca çok JA ili + JD1 adaları ile QSO yapabilmesi.
Japonya'daki amatör ise münkün olduğunca DXCC amatörleri ile QSO yapabilmesi.
YARIŞMA DÖNEMİ/TARİHİ:
  CW Mode 0700 UTC 12-Nisan / 13:00 UTC  13-Nisan
  SSB Mode  0700 UTC 14-Kasım / 13:00 UTC 15-Kasım   2015
BANTLAR:
 CW 1.8/3.5/7/14/21/28MHz (1810-1825 & 1907,5-1912.5KHz JAS)
     (3525-3575 JAS, 3599-3612, 3680-3687, 3702-3716 3745-3770 ve 3791-3805KHz ,7030-7200KHz ayrıca)
  WARC bantları hariç.
YARIŞMAYA KATILIM KATEGORİLERİ:
3-1.Single Operatörü (* 1) Yüksek Güç (* 2)
    Kısaltma = kategori
    AB          = TEK-OP ALL-BAND YÜKSEK GÜÇ
    28          = TEK-OP 28MHz TEK-BAND YÜKSEK GÜÇ
    21          = TEK-OP 21MHz TEK-BAND YÜKSEK GÜÇ
    14          = TEK-OP 14MHz TEK-BAND YÜKSEK GÜÇ
    7            = TEK-OP 7MHz TEK-BAND YÜKSEK GÜÇ
    3.5         = TEK-OP 3.5MHz TEK-BAND YÜKSEK GÜÇ
    1.8         = TEK-OP 1.8MHz TEK-BAND YÜKSEK GÜÇ
3-2.Single Operatör Düşük Güç (* 3)
     ABL = TEK-OP ALL-BAND DÜŞÜK GÜÇ
     28L = TEK-OP 28MHz TEK-BAND DÜŞÜK GÜÇ
     21L = TEK-OP 21MHz TEK-BAND DÜŞÜK GÜÇ
     14L = TEK-OP 14MHz TEK-BAND DÜŞÜK GÜÇ
      7L  = TEK-OP 7MHz TEK-BAND DÜŞÜK GÜÇ
    3.5L = TEK-OP 3.5MHz TEK-BAND DÜŞÜK GÜÇ
    1.8L = TEK-OP 1.8MHz TEK-BAND DÜŞÜK GÜÇ
3-3.Multi Operatörü (* 4)
     MOP = ÇOK OP. (TEK-TX ALL-BAND YÜKSEK GÜÇ)
3-4.Maritime Mobile (* 5)
    MM = Deniz araçları Mobil
QSO DEĞİŞİM BİLGİLERİ:
   Japon istasyonları : RS (T) + bölge numarası (01-50)
   Diğerleri istasyonlar: RS (T) + CQ Bölge numarası
Japon bölgesel kod numaralarının ayrıntılarına şuradan bakabilirsiniz  Linklerin Görülmesine İzin Verilmiyor. Üye Ol ya da Giriş Yap
Yadan bunu liste halinde text formatında şuradan indirebilirsiniz    Linklerin Görülmesine İzin Verilmiyor. Üye Ol ya da Giriş Yap
PUANLAR
Japonya <> Diğer ülke veya MM istasyonları QSO ları puan alır.
(DX<>DX, DX-/MM veya JA<>JA  QSO ları hiçbir puan ve çarpan alamaz)
      1.8MHz .............................. 4pts
      3.5/3.8MHz ........................ 2 puan
      7MHz, 14MHz ve 21MHz .... 1 puan
      28MHz ............................... 2 Puan
Aynı istasyonlar aynı band da 1 kez QSO yapabilir. Çapraz mode QSO 'ya izin verilemez.
ÇARPAN:
Japon istasyonları : Her  bandda 1 defa çalışılan DXCC ülkesinin CQ bölge numarasına göre çarpan alır
Diğerleri Ülkeler: Her bandda 50 Japon bölgesinden çarpan alabilir yani çalıştığı bandlarda yakaladığı Japon bölgesinden 1 defa çarpan alır.
SKOR / PUANLAMA:
Son puan sonucudur , (Toplam çarpanı) x (Toplam QSO puan) çarpılır.
Ör. 100 QSO puan x 59 = 5.900 multi
LOG TALİMATLARI:
** Kullandığınız çağrı işareti için sadece 1 log gönderiminiz kabul edilir.
 ph@jidx.org   e-posta adresine 11-ARALIK -2015 tarihine kadar gönderilmiş olmalıdır.
TA5FA TARAFINDAN ÇEVRİLMİŞTİR.
Linkback: https://www.radyoamatorleri.com/index.php?topic=5019.0
« Son Düzenleme: 09 Kasım 2015, 00:27:32 Gönderen: TA3CY »
Ynt: JAPONYA ULUSLARARASI DX YARIŞMASI 2015
« Yanıtla #1 : 13 Kasım 2015, 01:49:09 »
2015 CQ World Wide DX Contest // 2015 CQ Dünya Çapında DX Yarışması
Başlatan TA1LSE
3745 Gösterim
Son İleti 22 Ekim 2015, 18:27:47
Gönderen: TA3LOS
CQ-M Uluslararası DX Yarışması 2021
Başlatan TA4RC
951 Gösterim
Son İleti 05 Mayıs 2021, 22:10:13
Gönderen: TA4RC
Afrika All Mode Uluslararası DX Yarışması 2025
Başlatan TA4RC
202 Gösterim
Son İleti 22 Mart 2025, 13:04:08
Gönderen: TA4RC
2015 CQ Dünya Çapında DX Yarışması CW 28/29 Kasım
2710 Gösterim
Son İleti 24 Kasım 2015, 01:03:16
Gönderen: TA3LSD
Japonya'dan telsiz getirtmek
Başlatan ta1iog
1213 Gösterim
Son İleti 29 Ocak 2020, 23:15:31
Gönderen: ta1iog
